Part Number: DS90CF386
Hi
My customer want to test RxOUTxx pin open check with customer board at customer production test.
They know the method for RxOUTxx to low that is PWRDWN =low.
They want to know the method for PxOUTxx pin to high. (not use LVDS signal)
- Is there a simple way to make each RxOUT ** terminal to High?
- Is it possible to make RxOUTxx High / Low by inputting TTL signal in RxINxx instead of LVDS signal? (Without LVDS clock)
- The LVDS clock is described as 20 MHz or more,
Can I slowly input RxOUT ** High / Low together with data with a slow signal in it?
This questions are for only inspection. Actual use is operated according to the specifications.
Muk
