Part Number: DS90UB954-Q1
Other Parts Discussed in Thread: ALP
I am using the DS90UB954/953 with 10 meters of 50 ohm coax in CSI non-sync mode running a single channel of 1080p60(10-bit bayer data). The system is working nicely but we are seeing glitches(LOCK is negating) every few seconds and slowly gets better over the first 5 minutes and slowly stabilizes to a fairly solid video stream with a glitch every 1 hour or so.
This suggests to me the '954's AEQ is still slowly adapting over the first 5 minutes and may not be ideally adapted to our cabling. Our coax setup is not ideal with the 4 points of connectors in the cable run.
Is there some process that can be done at startup to help the AEQ adapt the best?
Any other thoughts?
Tim
