Part Number: DP83867IR
Other Parts Discussed in Thread: AM3352
Hi teams
My customer is using DP83867 with AM3352 in a new project(They use Marvell's solution in the past. Below is their question:
- Do we have any application note or guideline about the register and strap connection configuration?
- DP83867 have several LED PIN, these pins can also be used as strap detection. The datasheet shows the connection about MODE1/MODE2/MODE4 but didn' give the MODE3 connection.
- If we don't need the LED indicator function could we use 2 resistors to create wanted voltage level to finish strap connection without LED diode?
- How to determine the clock skew parameter?
