Part Number: THVD1550
Other Parts Discussed in Thread: THVD1500, SN75176B
Hi Sirs,
Sorry to bother you.
We have use THVD1550.
Our issue is we found our THVD1550 pin 6 (DE) if pull low, that will still to effect pin7 state.
The other word is RS232 TX waveform will be different between U83 THVD1550DR pin 6 have connect or disconnect. please refer as below.
As my understand when DE low, AB will be high-z, right?
Actually we try competitor ADM485 that didn't find this phenomenon.
Based on TI cross reference them should be P2P.
We guess the waveform is cause high-z impedance value not large enough?
So, we would like to know,
1. Why THVD1550 have this phenomenon?
2. How to check the IC in Hi-z? like use volt-ohm-milliammeter to get impedance value? how to connect volt-ohm-milliammeter ?
Postive connect to Pin6 (A) and Negitive connect to Pin5(GND)
3. What is the Hi-z correct value? 10M? 100M?
Waveform: not disconnect pin6. ch1 is pi6 and ch2 is pin7
Waveform: Disconnect pin6 Tx. ch1 is pi6 and ch2 is pin7
Schematic:
