Part Number: TCA9555
Other Parts Discussed in Thread: TCA9535
Hi Sir,
When we use GPIO mode to enable/disable device(default is disable device) how to connect this I/O pin at power on configure as an input??
Hey Anne,
TCA9535 also starts up as an input but is HI-Z (no internal pull up like you pointed out). You can either reference the pin with a pull up or pull down resistor depending on your preference. So in your example, you want to keep the device tied to a GPIO as a default disable therefore if GND keeps the device disabled then you would tie the GPI to GND.
I hope this makes sense.
-Bobby
