DP83822I: How to judge whether the signal is no problem or problem.
Part Number: DP83822I
 Hello guys,
 One of my customers is evaluating DP83822I on their own PCB with the attached configuration.
 They want the answers for the following questions.
 Could you please give me your answer for the questions?
Q1. How to judge whether the signal is no problem or problem
   Is there any document for judging?
Q2. What is recommend voltage level of signal receiving terminal (RD_P, RD_M)?
     Is ther any information or regulation for the terminals?
  Your reply would be much appreciated.
 Kazuya Nakai.
/cfs-file/__key/communityserver-discussions-components-files/138/DP83822I_5F00_customer_5F00_configuration.xlsx
  • Hi Kazuya,
    Q1. Typically IEEE compliance will be run by a customer to determine if an Ethernet design is acceptable. That process is done with specialized test suite on an oscilloscope. Or it is done by setting up the tests as shown in IEEE standards. We have an app note discussing setting up the testing if using an automated compliance suite. www.ti.com/.../snla266
    Q2. The RD thresholds are not specified as per IEEE. The TX VOD is specified and the media is specified by IEEE. The receiver of the DP83822 is tested with the worst case conditions of both VOD and cabling. When doing IEEE compliance, only the TX parameters are tested.
  • Hi Rob,
    Thank you for your reply.
    Your answered for Q2 that the receiver of the DP83822 is tested with the worst case conditions of both VOD and cabling.
    Could you please tell me what the worst conditions of both VOD and cabling are?
    Thank you again and best regards,
    Kazuya Nakai.
  • Hi Kazuya,
    The worst case channel and VOD is captured in the IEEE specification. Please get it from IEEE 802.3 specification. Clause 25 handles 100base-tx.
