Part Number: TPIC8101
Hi Team,
The INT / HOLD terminal is set to output or hold from the integration stage.
Where is the extraction done in the block diagram?
Is it "Programmable Integrator"?
Kenji
Hi Team,
Kenji
Hi Clancy,
Thank you for your reply.
However, what I wanted to know is the delay time that is supposed to occur when changing the integration mode when INT / HOLD is changed from low to high.
Since there is a filter up to "Programmable Integrator", I think that delays will occur as shown in the figure.
There was no information on the regulation in this datasheet.
Kenji
Hi Clancy,
Thank you for your answer.
My customer have begun consideration for using the device.
I understood that there really is a delay time.
If possible, can you measure delay time of this device?
I would like to see concrete performance data.
Kenji
