Part Number: DS25BR440
Other Parts Discussed in Thread: DS10BR150,
Hi Team,
My customer is looking to use the DS25BR440 and DS10BR150 to drive across a 7 meter PCIe cable rated at 3.125GHz and has a couple questions:
1) Can they use AC coupling after the driver, or between two drivers at either end of the cable?
- The DS25BR440 data sheet on page 11 (Output Interfacing) says DC coupling is OK on the output, but doesn’t mention AC coupling. Does this exclude using it? Why?
2) Would you recommend using the part at each end of the cable? We think maybe the equalization function is better used at the driver to handle PCB board trace differences, and may not be needed to handle cable input differences. What do you think?
3) On the DS25BR440, what is the supply current and/or power saved by powering down each individual channel?
Mitchell
