Part Number: DP83848Q-Q1
Hi team,
I have some qustions about RBIAS pin.
Our customer designed the board mounted DP83848Q-Q1.
The boards were assembled, but with mistake it was supposed to connect a resistor of 4.87 kΩ to the RBIAS pin, but 20 Ω was mounted.
At this time, turning on the power will cause a large current to flow through the device, causing large heat generation?
They say that the device got very hot.
Could you explain the function of the RBIAS pin and why it should be connected to GND 4.87 kΩ?
Tomoaki Yoshida
