Part Number: TLK10002
Hi Team,
What's the acceptable ripple range of each power supply of the TLK10002?
Hi Team,
Lilian,
There is no spec for acceptable voltage ripple for TLK10002 however I recommend you follow the decoupling scheme similar to the is on the TLK10002EVM and that the voltage ripple does not cause any power rail to exceed the datasheet limits. The decoupling scheme should prevent most high frequency noise from reaching TLK10002.
