I have a question about DP83TC811R LED_0 pin configuration.
I plan to use this PHY IC as 100BASE-T1 Master, so I need to use 2.49kohm pullup resistor which table 17, 18 mentioned.
Also I plan to use LED for LED_0 pin.
In this case, can I only use pull down resistor for LED which figure 28 mentioned?
And, what resistor value should be used for Rp and Rcl?
I would be grateful if you could give me reply.
Ryo Akashi
