Part Number: DS90UB948-Q1
Dear TI Experts,
I‘d like to use LUT function and I am a little confused about it:
①As is described in the datasheet
"Load contents of all 3 LUTs . This requires a sequential loading of LUTs - first RED, second GREEN, third
BLUE. 256, 8-bit entries must be loaded to each LUT. Page registers must be set to select each LUT".
Should I write the LUT after config REG2A PageSetting and directly from address 0 ?
②When DS90UB948 is powered off,will the LUT remain its value? If I need the LUT function, must I rewrite LUT after DS90UB948 reset?
③Does DS90UB948 have the function that get the LUT from a connected EEPROM and loading by itself?
