Part Number: SN75DP130
Other Parts Discussed in Thread: TDP142
Hi Team,
one of our customer is thinking to use the SN75DP130 in a industrial Monitor.
The Display in this monitor has a Display port interface (DP 12., 2 Lanes with aux channel and HPD pin).
To compensate for disturbances and losses on the cable, they would like to use a redriver or retimer.
One of the ideas is to use the SN75DP130. There will not be a MCU in the monitor itself.
The SN75DP130 is configured via I2C. Is there a possibility to use this part without the I2C connection?
If not, can you recommend a other part that can fit into this application?
Thanks for your help.
Best regards
Martin
