Part Number: DP83822I
Other Parts Discussed in Thread: DP83822EVM, DP83822HF
Hi Team,
An MDIO communication error occurs in DP83822I.
I tried MII communication with the MCU using DP83822EVM, but it will be successful.
Is there a difference in hard connection between DP83822HF and DP8322I?
In EVM, after RESET, RX_ER goes high and goes low, and RX_CLK starts outputting at the same time.
However, in the mounted DP83822I, RX_ER does not fall to Low and RX_CLK is not output.
Do you know what is the factor?
Kenji
