Part Number: LMH1297
I’m wondering if the capacitors connected to VDD_LDO will drain with the 2V5 rail if the 2V5 rail is connected to ground? I have a use case where I need to discharge all rails on our board and I’m wondering if I need a separate discharge FET connected to the LDO caps or if my discharge FET connected to the 2V5 rail will pull the charge from the LDO caps too? Thanks.
