Part Number: AM3352
Other Parts Discussed in Thread: AMIC110, DP83822I
Our AM3352 based application will be using DP83822 as Ethernet PHY(CPSW).
And there is a little confusion about Ethernet Resistor Strapping.
We couldn't find EVMs other than ICE board to refer AM335x + DP83822 schematics.
In case of AMIC110 ICE, the user guide mentions that Software should turn off internal pull resistors
of these pins to prevent AMIC110 internal pull resistors from interfering with the bootstrapping of Ethernet PHY.
In our application both AM335x and PHY would be powered-up at the same time
so it would be difficult to control the AM335x internal pull resistors in software.
So it would be easy for us if we can add external resistor to overcome the internal pull,
could you please let us know if there is any suggestions on the values of external pull resistors
that could be used to overcome internal pulls of AM335x ethernet related pins.
It would be very helpful if there is any reference schematics of AM335x + DP83822 (CPSW mode).
Best Regards
paddu
