Part Number: TPS65987-90EVM
Other Parts Discussed in Thread: TPS65987D, DP-EXPANSION-EVM
1. Using TPS65987-90EVM Eval board with DP expansion Board EVM. I have noticed TPS65987-90EVM board has GPIO2 (which corresponds to MUX_USB) is hooked to the MUX enable pin. Due to this, I am not able to pass video unless that pin is disabled through firmware. Is there any particular reason for this connection?
2. TPS65987D-90EVM user guide shows type C connector pin A8 as C_SBU_P. According to Display port alternate mode this should be AUX_N (assuming straight plug connection and UFP_D pin assignment). Please clarify.
3. Regarding TPS65987D FLASH, do you have any list of compatible or working SPI FLASH ?
