Part Number: DS90UB953-Q1
Other Parts Discussed in Thread: DS90UB954-Q1
When using coaxial TX RX with ds90ub954-q1, what is the trace impedance layout between IC and coupled capacitor?
thanx
Ray
thanx
Ray
Hi
Thank you for the info.
We know the trace between fakra and ac cap is 50 ohm single ended.
We are not sure if the trace between 954 IC pin and ac cap is 50 ohm single ended too.
And It seems to be 100 ohm differential pair even if we use coaxial(fakra) POC solution.
We have the same problem on 953 side too.
Ray
