Part Number: DP83867IR
The data sheet recommends a 11Kohm resistor to ground from RBIAS. However we accidentally put a 2.2Kohm resistor instead and had powered up the board. Since then we realized the error and changed the resistor. Our question is given the operation of RBIAS is it possible the device is damaged in any way? We need to know as this will dictate if we need to replace the IC.
Thank you,
HSG
