Part Number: DS90UB953-Q1
Other Parts Discussed in Thread: ALP
Team,
I have a customer prototyping with '953 and '954 serializer/deserializer.
They are able to run the script that initiates the camera, and they get the vertical and the horizontal parameter as stated in the documentation. All the testing shows pass and locked and the script ends, but they aren’t able to get the csi-2 signal from the output of the ti953.
Also, they noticed that if they connect both the 953 and the 954 at the same time and use Alp software, it freezes, but connecting one or the other only will not cause that freeze. Do you have you any idea what could be causing that? Do you have you any recommendation on how to keep the camera running and transmitting all the time?
