Part Number: TCAN4550-Q1
In Figure 21, it states RST pin: Set high to reset device, once finished set back low. I know the minimum high time is 10us, what's the reset time needed after RST low rises to high? Maximum 10us? Thanks.
Wayne,
Can you show me in the datasheet where you're seeing the 10us requirement? In the datasheet I'm referencing, the parameter tpulse_width is what defines the minimum time the reset pin needs to be held to assert a device reset. The RST pin is low by default, then a pulse high of minimum 30us to trigger the device reset.
