Part Number: DP83848K
I need to test the physical layer of Ethernet signal, ANSI standard, using DP83848, how to set up DP83848 register output standard protocol signal.
I need do Ethernet compliance test for 10BASE-T,100BASE-TX, and 1000BASE-T,use DP83848 ,can you provide me the DP83848 setting file such as the file of Microchip PHY?
AN2686-Ethernet-Compliance-Test-10BASET-100BASETX-1000BASET.pdf
