DP83867E: 125MHz generation from CLK_OUT signal pin
Part Number: DP83867E
I am connecting CLK_OUT signal pin output from the Ethernet PHY to RGMII GTX_CLK125 pin on Processor T2081. The GTX_CLK125 pin requires 125MHz constant clock as per the datasheet of T2081.
When I am connecting 1Gbps signal from my PC to PHY chip I am getting 125MHz on CLK_OUT pin. But if I am connecting 100Mbps signal from my PC to PHY chip I am getting 25MHz on CLK_OUT pin. Which setting should I use on the PHY to get constant 125MHz through the CLK_OUT signal pin?
