Compiler: ds16ev5110asq EQ Booster register setting difference value is not useful in disitance
When debug  DS16EV5110ASQ  EQ Booster register ,the output extension distance is not changed , but though seting exteral hardware part ,the function is OK . so pls give me guideness how to enbale the EQ booster register function,thanks!
  • Hi Roger,
    You mentioned through external hardware part it is ok. Please clarify what you mean by this?
    If I understand you correctly, you are saying if you use SMBus register to set boost you have problem but when you use BC_2 through BC_0 device correctly equalizes your cable? Could you please clarify.
    Regards,,nasser
  • Hi Roger,
    It's been more than three days with no update or response to this case. I am assuming this issue is resolved now. We close this case for now. Please re-open this case when you have a new update related to this issue.
    Regards,,nasser
