Part Number: TCA9545A
Hi ,
I planning to use I2C, TCA9545A switch, to calculate pull up resistance value for slave do i need to sum the trace capacitance for both the lines SCL and SDA?
for example SCL signal has trace capacitance - 25pF, SDA has - 25pF, as i have 4 slaves the should i consider bus capacitance as 200pF or 100pF?
