SN65HVD12: Communication Problem
Part Number: SN65HVD12
Please find the problem description as enclosure. and please offer the comments. Very thanks.
RS485 Communication Problem.pdf
Brian
  • Brian,
    Do you mean when the abnormal communication happens, the voltage level of A/B are not big enough therefore the receiver doesn't toggle? Does observed the behavior go away after a while or it stays? Would the problem disappear with new IC? What TVS diode are used on the pins? What's the data rate and communication distance in this application? Is there any ground potential difference between the transmitter and receiver? If the customer information is sensitive, you can send me email hliu@ti.com for further discussion.
    Hao
  • Hi Brian,
    Have you had a chance to look into Hao's questions above?
    Max
