Part Number: DP83867IR
Hi Team,
When I checked the relation between "7.14 10-Mbps MII Transmit Timing" and "Figure 10. 10-Mbps MII Transmit Timing" on the datasheet of DP83867IR, the "Figure 10. 10-Mbps MII Transmit Timing" seems to be not correct.
Could you review the "Figure 10. 10-Mbps MII Transmit Timing" and let me know the correct 10-Mbps MII Transmit Timing figure?
Thank you.
Koshi Ninomiya
