Part Number: DP83822H
HI,
The DP83955AV is no longer available. I need a suitable replacement. Can you recommend if this device DP88322H is suitable replacement or is there a better choice? It will be easiest to find a copy of the DP83955AV data sheet on line for review. However here are some of the key features:
Compliant with the IEEE 802.3 Repeater Specification, 7 network connections (ports) per chip, selectable on-chip twisted-pair transceivers, cascadable for large multiple RIC/LERIC hub applications.
Thank you,
HSG
