Part Number: DP83867CS
The SNLS504B datasheet for this part simply states that, "It has low jitter". Do you have any numerical data to characterize what is meant by "low"? For instance, assuming data coming into the PHY has a known jitter from its source, what max additional jitter should be expected from the PHY itself as the data is transmitted out onto the network?
Thank you,
Jim
