Part Number: DP83822I
Hi team,
Customer will use Dp83822i and they have some questions below:
- What is meaning of the below words from datasheet . What is the value of this suggested pull down resistor ?
"The do83822 requires clock to be present at PoR. In case clock is delayed, pull-down on XI is recommended to avoid spurious signal latch-up."
2.In datasheet , it describes force modes and Advertised Modes. What is the difference between them?
Could you help with the two questions? Looking forward to your reply and thank you!
Marc
