Part Number: TPS65983B
Other Parts Discussed in Thread: TPS65988
Dear sir
We are going to apply RS5 driver WU (Windows Update) for our customer. But while we were using MDA audit tool to check driver WU status, we found that the UCM driver you provided “Signed_RS5_TPS65983_1_0_2_2_UCM.zip” cannot pass MDA check. We need TI to submitGK5CP6T_20190524.txtGK5CQ7T_20190524.txt WU to Microsoft for us so that the MDA check can pass.
The log info is as below. Please check the logs as the files attached for more detailed info. Thank you.
69 Device Instance ID: ACPI\INT3515\0
Matching HWID: ACPI\INT3515
Parent HWID: PCI\VEN_8086&DEV_A36A&SUBSYS_20868086&REV_10\3&11583659&0&AA
All HWIDs: ACPI\VEN_INT&DEV_3515;ACPI\INT3515;*INT3515
Compatible HWIDs: (null)
Problem: 0
Status: 0x00000000
Description: TPS65983 Device
Submission ID: 30042100_14069210441029452_1152921504627925574
Driver Flight Ids: None/Unknown
Universal: True
Declarative: True
Provider: Texas Instruments
Class: System
Class GUID: 4d36e97d-e325-11ce-bfc1-08002be10318
Driver Version: 1.0.2.2
Driver INF name: oem60.inf
Original Driver INF name: TPS65983.inf
Installed extension INF count: 0
Base Driver Date: 06/12/2018
Driver store filename: C:\Windows\System32\DriverStore\FileRepository\tps65983.inf_amd64_f12368698ac89c21\tps65983.inf
Driver score: 0x0d000005
Driver rank: 0x00ff0001
Driver Install Date: 5/23/2019
[FAIL: Older Base Driver on WU (Installed Driver: 06/12/2018:00:00:00 / WU driver: 04/13/2018:00:00:00 / WU Update ID: {5a7c9496-375e-4941-9816-c0e2722079a8} / WU Revision: 1)]
Base WU driver date: 04/13/2018
WU Provider: Texas Instruments
WU Driver Manufacturer: Texas Instruments
WU Driver Model: TPS65988 Device
WU Update Title: Texas Instruments - System - 4/13/2018 12:00:00 AM - 1.0.2.6
WU Offered Device ID: acpi\int3515
WU Revision: 1
WU Class: OtherHardware
