Part Number: DS90CF386
Other Parts Discussed in Thread: DS90C385A, DS90UB925Q-Q1, DS90UB926Q-Q1
Hi
Could you please let me know the Spread Spectrum range of DS90CF386?
- Spread rate : +/- xxx %
- Frequency modulation : xxx kHz
Muk
Hi
Muk
HI Mukuno-san,
I will check the charaterization report if this was tested.
Hi Nukuno-san,
I have checked our archives and there was no spread spectrum tolerance tested.
If the datasheet does not have a specification, then I would not recommend applying spread spectrum.
Hi Jeong-san
Thank you for your answer.
Do you have any solution for recommended device that can apply spread spectrum?
Mukuno
Additional comment.
DS90C385A(Tx) has the spec of SSC.
(From DS90C385A Datasheet)
> Support Spread Spectrum Clocking up to 100kHz Frequency Modulation and Deviations of ±2.5% Center Spread or -5% Down Spread
Could you please recheck this?
DS90CF386 cannot accept applying SSC. But, DS90C385 can accept SSC.(?)
Hi Mukuno-san,
The DS90UB925Q-Q1 and DS90UB926Q-Q1 accepts spread spectrum
http://www.ti.com/lit/ds/symlink/ds90uh925q-q1.pdf
http://www.ti.com/lit/ds/symlink/ds90uh926q-q1.pdf
What is the volume opportunity?
Darryl
Darryl-san,
I try to propose new devices.
However, Please give me your answer for my question about DS90CF386 SSC.
Muk
Hi Mukuno-san,
We do not have any SSC tolerance data for the DS90CF386 at this time.
Darryl
