Part Number: SN75DP159
Other Parts Discussed in Thread: SN65DP159
My customer has noticed a change in the datasheet solder pad size from Rev A to Rev F of the datasheet.
- Solder Pad size: 0,85 x 0,28 (rev A) vs 0,60 x 0,24 (rev F) , see red arrows.
- Center of the pads is 6,95 (rev A) vs 6,80 (rev F) .
- Overall the pad Layout dimension was 7,8mm at rev A, but in the rev F is 7,4mm
They're fine with changing it but want to ensure that the Rev F dimensions are correct. Can you comment?
