Part Number: TUSB4041I
Tool/software: Linux
Hi, Ti:
We used the tusb4041i hub as the msm8996 usb2.0 host's slave device. Now we had tested the hub's downstream port's eye pattern,
but the left canthus is not open enough, it cause the test result is fail. We had replaced the USB_R1 resistor from 9.53kΩ to 8.25 kΩ,
but the effect had not been improved.
What's the reason of this problem? Which parameters fo the eye pattern we should adjust?
Can I tuning it by modifying the boost value of the eye pattern register? I haven't the eye pattern
register's datasheet of tusb4041i hub, can you give me one?
