Part Number: SN65C1168E
Hi, Team .
could you see below?
1. the spice model spec depends on the power supply and load ?
2.in order to get the more real result, should customer re-change the spice model internal spec ?
3.which sentence can customer change (which line should customer change in spice model)?
4.if customer assumes like below , how customer consider about cable for getting more real result ?
(should they write any spice information with cable impedance ? cable distance ?
<customer system+SN65C1168E> connected cable <Load>
5.if customer has to change the output impedance in spice model, does this mean that the I-V characteristic is non linearity ?
6.can you share I-V characteristic data ?
