Part Number: ONET4211LD
I intend to disable the APC loop, when I do I need to know the following:
1. If the diode at PD is removed, the current there should be zero. Is it safe to remove the MONP resistor in this mode?
2. If the APC loop is disabled, does there need to be a 100nF capacitor connected to CAPC?
Thank you,
HSG
