Part Number: P82B96
Hiya,
I'm looking for some help regarding wiring this P82B96(P). I am using it in this configuration which I believe to be correct. The intention is to transmit I2C up to 100m from master to slave.
I am going to terminate this into an RJ45 screened connector and go over CAT6. I'll have to work out the resistor values for this unless you can give me a starting point to try.
My question is how to wire from a slave to a slave. (if it's possible) I have attempted to illustrate my question below. Does each slave require two P82B96's to forward the signal on? Please note that each slave has a 12v supply.
