Part Number: SN65DP159
Dear Team,
In the datasheet, it use 65k ohm pullup/ pulldown resistor for the control pins.
My customer would like to use 60.4k ohm resistor. Is it ok?
What is the tolerance requirement?
Thank you.
Jim.
Dear Team,
Thank you.
Jim.
Jim
Resistor tolerance is 65k +/- 10%.
David
Hi David,
I just confirmed with Win this week. He said 65K ohm resistor for pullup and pulldown resistor is for mid-level.
But if the customer doesn't use mid-level for control pins, 10k ohm should be fine for high-level and low-level.
Thank you.
Jim
Jim
Please see the note in the datasheet:
(H) Logic high (pin strapped to VCC through 65-kΩ resistor); (L) logic low (pin strapped to GND through 65-kΩ resistor); (for mid-level, no connect).
David
