Part Number: DP83867IR
Hi
How can we disable RX data when the broadcast packet is received at WOL enable?
Because the processor is wakeup when the broadcast packet is received even if INT does not change.
INT signal is changed to Low from High correctly when the magic packet is received.
And it wakeup as we expected. However the behavior is not as expected when the broadcast is received. Is this behavior is normal?
The processor does not wakeup when WOL is disabled even if the broadcast is received.
(Wakup: This means that the state of processor changes from " Suspend" to "Resume".)
MICR : 0x0008
Koji Hamamoto
