TCA9554A: Variation range of internal pull-up resistor
Part Number: TCA9554A
Hello support team,
The IO port of TCA9554A has a built-in pull-up resistor, which typical value is 100 kΩ.
What is the variation range (maximum and minimum value) of this pull-up resistor?
Sincerely,
M. Tachibana
  • Hello M. Tachibana,
    The pull up resistor value is not a electrical characteristic so finding char-values for this pull up resistance is not easy.
    Would it be sufficient if I measured the pull up resistances myself with a digital multimeter for ~5 units and we make an assumption of a tolerance of around 10% for the value I find?
    Let me know if this kind of data would be okay with you.
    -Bobby
  • Hello Bobby-san,
    Sorry for my late reply.
    Thank you for your comment.
    I understood that the variation range of internal pull-up resistor is not known because its value is not a particularly controlled characteristic.
    Considering the manufacturing variation of semiconductors, I thought it would be better to estimate around ± 15 to 20%.
    Sincerely,
    M. Tachibana
