Part Number: DP83848I
Hello Experts,
My customer would like to replace from LXT972A to DP83848 and have a question as follows. Would you answer them?
1. Customer is using TXSLEW0/1 of LXT972A. Customer wants to know what function would be corresponding for by DP83848.
2. Customer wants to display an activity of LED, controlled by CFG_LED(0). He needs to display RX activity only. Can DP83848 this setting?
3. For MII Isolate mode, datasheet stated that DP83848 will be in MII isolate mode by strapping physical address 0. In case of start up of DP83848, customer should use other physical address, or it stay physical address 0 and then disabled MII isolate mode by register setting (BMCR register/bit 10), is my understanding correct?
Fujiwara
