Part Number: DS125BR820
Hi Team,
We use DS125BR820 as a SATA redriver, and use SMB master mode for EEPROM.
1. Could we use one EEPROM shared with 6 re-driver? Is there any concern? One EEPROM is used for 6 re-driver config.
2. Does EEPROM data used by re-driver must be wrote from address 00h? in our case, 00h data may be reserved for other device.
3. Spec. p19, For transfer rate 1MHz, the redriver exactly access data under 1Mhz? is it workable if we use 400Khz or 100Khz device?
