Part Number: DP83869HM
The datasheet shows that “Signal detect” can be enabled/disable on pin 24 (JTAG_TDI/SD) through strap option in 1000Base-X (Table14. 1000Base-X Strap Table) and 100Base-X (Table15. 100Base-X Strap Table) mode.
When the PHY is strapped to boot in Copper Ethernet mode (Strap OPMODE(2:0) = 0x0) and then changed to "RGMII to 1000Base-X" mode through Serial Management Interface (MDC/MDIO), is it possible to enable the Signal Detect on pin 24 (JTAG_TDI/SD) through Serial Management Interface (MDC/MDIO)?
Thank you.
