Part Number: TCA9539-Q1
Other Parts Discussed in Thread: TCA9539
I want to connect multiple INT (each from one TCA9539) to the same line due to lack on of available pin on my micro-controller. Each TCA9539 is supplied by its own power supply, which can be turned ON or OFF. There is on pull-up resistor for the whole INT line, on an independent power supply.
My question is: "Is there an internal connection between the VCC pin and the INT pin (e.g. protecting diodes, … )?" , i.e. will shutting down one TCA9539 (connecting its VCC to GND) pull down the whole INT line to GND?
Jules
