Part Number: DP83867CR
Other Parts Discussed in Thread: DP83867IR
DP83867CR's datasheet is quite laconic about interpretation of TDR results.
I tried equations from snla253, but that document applies to DP83822. For DP83867CR, it gives results that do not match the cables I tested (roughly 2x the real cable length is reported).
I cannot find actual computation needed to get from TDR_PEAKS_LOC* to a length. Did I overlook some part of documents ? Could someone provide it ?
Also, snla253 mentions a "Peak polarity" in "Register 0x018A bit [15:6]". DP83867CR datasheet doesn't mention peak polarity at all. Where should we take the sign bits from ?
Thanks in advance.
