it shows suitable for 60-fps WUXGA 1920*1200
If the display spec is 1920*720 /60FPS, 2Port LVDS (8 bit, VESA, DE mode)
but required output would like to have 720*1920/60fps, will there be any issue by using this part?
Hi Patty,
I don't understand your question. If the display spec is 1920x720, why would the required output be 720x1920?
I.K.
sorry for confusing, per checked again, the question is, is it possible to support 720*1920/60fps for portrait display? Thanks
Patty
Hi Patty,
Yes, this device can support 720*1920/60fps. You can reference number 7 in this application note to determine whether or not a resolution can be supported: http://www.ti.com/lit/an/slla356/slla356.pdf
I.K.
