Part Number: TCA9517
Other Parts Discussed in Thread: TCA9548A
Customer is using TCA9517 between one I2C master components and six I2C slave components as described below.
- VCCB(3.3V) side connected to I2C master with external pull-up resistor 4.7kohm.
- VCCA(1.8V) side connected to five TCA9548A chips plus one clock generator (https://www.idt.com/document/dst/5l35023-datasheet)
- There's one set of 4.7kohm pull-up resistor @ clock generator.
- There's another set of 4.7kohm pull-up resistor @ TCA9517 SDAA/SCLA
Now they observe some unexpected bump like below, and need our comments for the root cause. Can you share your inputs? Is it normal there're totally two sets of 4.7kohm external pull-up resistor at A-side(slave side)?
THanks!
Antony
