Part Number: SN65LVDT34
Hi Team,
With respect to the SN65LVDT34, the datasheet states the inputs are high impedance when powered down, but what about the output state when powered down?
Hi Team,
David
At the EQUIVALENT INPUT AND OUTPUT SCHEMATIC DIAGRAMS, the input is already high impedance. There is a diode between the VCC and the Y output. So VCC is off and goes to GND, then the Y output will be ground as well. But if VCC is off but floating, then Y output will be floating as well.
David
