Part Number: LMH1297
Other Parts Discussed in Thread: LMH0302
Hi; we use LMH1297, have encountered some problems. Could you please give me some Suggestions,Thanks!
A, LMH1297 use as equalizer, directly connected to the FPGA,when input 6G signal, PFGA can recognize & work properly; But when 12G signal input, PFGA can not recognize properly,Currently there is no 12G test equipment, Cannot test the LMH1297 output signal,Could you help check the schematic diagram &PCB? or need to change the configuration of LMH1297?
B ,LMH1297 use as Driver;the eye diagramis normal when HD/3G HD output. But when Output SD Video Singal,the rising edge of eye diagramis is about100PS;Required value 400 ~ 1500 ps;Similar to LMH0302, it has SD/HD selection pin .Does LMH1297 have similar functions (registers) for configuration selection? Thanks!
