Part Number: TUSB8041
Could you send me the EEPROM programming tool & image file with u1u2 disable?
Masumi Saito
Masumi Saito
For TUSB8041, the only registers that are commonly used are the following:
'TUSB8041 EEPROM Data File 'Created 08/08/2019 12:16:31 PM 00 55 01010101 01 51 01010001 02 04 00000100 03 40 01000000 04 81 10000001 05 10 00010000 06 00 00000000 'BC support All port disable 07 8F 10001111 'All Port removable 08 0F 00001111 'All Port Enable 09 00 00000000 0A 22 00100010 0B 00 00000000 F0 00 00000000 'DATA FILE FORMAT: <HEX ADDRESS><TAB><HEX DATA>. EVERYTHING AFTER <DATA> IS IGNORED. 'USE <'> FOR IN-LINE COMMENTING. 'DATA FILE PARSING STOPS AT FIRST BLANK LINE.
